Hi guys i am in a deep hole i dont know what to do. Well basically i have a strange noise like a clicking noise when ever i press on the brakes and yes i have check the pads and fluid still nothing but i do have a mount knocking is that a problem or not and will it get fixed? I know i have the top mount knocking as i am aware but i dont know how much its going to cost me any ideas? Please help me out guys.
Thank You
Help Plz
Assuming that there is no grit etc in the pads and that the discs are still round and flat, have you checked that the ABS is not causing a problem. Also that nothing is moving into contact with moving parts - like onto tyres or drive shafts?
"What you doing this weekend?"
"Fixing the car"
"What d'you expect - it's a Peugeot! Should have bought Japanese........"
"Fixing the car"
- neildavies
Lucky you found out that in time. Could have been nasty.
Not sure how you mean to check the abs, but to test it, find a gravel car park and slam the brakes on, you should feel the pedal releasing.
2007 307cc Sport 2.0 HDi 136
