Help Plz
Posted: Sat Feb 17, 2007 11:47 am
by PUG406SRI-Turbo
Hi guys i am in a deep hole i dont know what to do. Well basically i have a strange noise like a clicking noise when ever i press on the brakes and yes i have check the pads and fluid still nothing but i do have a mount knocking is that a problem or not and will it get fixed? I know i have the top mount knocking as i am aware but i dont know how much its going to cost me any ideas? Please help me out guys.
Thank You
Posted: Sat Feb 17, 2007 12:14 pm
by Just40in
Assuming that there is no grit etc in the pads and that the discs are still round and flat, have you checked that the ABS is not causing a problem. Also that nothing is moving into contact with moving parts - like onto tyres or drive shafts?
Posted: Sat Feb 17, 2007 12:50 pm
by PUG406SRI-Turbo
Thanks for your facts mate. I have just found out my calipers were lose as hell and the bolt has gone off and how do i check the ABS?
Posted: Sat Feb 17, 2007 2:51 pm
by neildavies
Lucky you found out that in time. Could have been nasty.
Not sure how you mean to check the abs, but to test it, find a gravel car park and slam the brakes on, you should feel the pedal releasing.
Posted: Sat Feb 17, 2007 6:14 pm
by Just40in
RE: check abs - all I meant was to ensure that clicking wasn't something going on in the abs module when pushing on the brake pedal.......
Posted: Sat Feb 17, 2007 6:38 pm
by mjb
Just40in wrote:RE: check abs - all I meant was to ensure that clicking wasn't something going on in the abs module when pushing on the brake pedal.......
Pull the fuse...
