Hi
Got a 2000 HDI 90 Rapier. 168K miles. Had it 10 years. Great car. Completed an oil and filter change and checked for leaks etc next day after a half hour run. Undid the oil filler cap and noticed a bit of blue smoke coming out under quite a bit of pressure. Never used to have any pressure when i've undone the cap on previous occasions. Car uses almost no oil and performance however seems same as ever.
Pulled off the big central breather pipe but only at the end at top where it meets the crankcase cover just to see what would happen. Nothing changed with pressure staying the same. Is it worthwhile to take the breather pipe off completely? Is there a filter in the breather that maybe needs cleaning out? Or is it all just wear and tear and keep fingers crossed?
Any hints infor be grateful as i really like the car.
Jim
Pressure under oil filler cap
Re: Pressure under oil filler cap
Sounds like a breather issue, could be worth removing it and looking at the bottom part, I know you've had the car a long time and this will sound daft but you haven't over-filled the oil at all?
Has the car been used for constantly short journeys? this can lead to a build up of residue in the breathers.
Put in the usual 4 1/2 litres oil and do varied journeys. Car used daily to work 12 miles each way. If take the breather off, do I need to drain oil from sump first?
You shouldn't need to as the breather should always be above the oil level of the sump. It'd be worth doing a bit of homework before you try the job, maybe have a new hose assembly and fixings to hand; these things have a habit of breaking when removed for the first time.JimH240 wrote:Put in the usual 4 1/2 litres oil and do varied journeys. Car used daily to work 12 miles each way. If take the breather off, do I need to drain oil from sump first?
To be fair I wouldn't worry too much about this if the car's alright otherwise, maybe ask if others with a 90bhp can check theirs does the same thing?
My car does the same thing but I know the head is venting in to the coolant system. Checked the top breather in to the air intake which was clear. I assume there are other pipes I need to check?
