I own a Peugeot 406 SV petrol 2L yaer 2000 with 188,000 km.
when i start the car after a long period of time (more then 8 hours) the car starts and have oscillating RPM after a few seconds it is choked and shutoff. it is happening each morning even when it's not cold. If I push the accelerator pedal during the choke of the motor, the RPM are going higher (obviously) and after several seconds i live the pedal the motor will not shutoff but the RPM is still oscillating. the oscillation will repeat itself every time the car stops\stands (in a traffic light for example).
I've have read the article in this forum "FAQ - 406 D8 petrol (Excl. V6) running and starting problem" and changed the steeper motor part, did the reset (turn the key to 2 position for 30 s the off ffor 30 s X 3 times, then start the car and drive it for 20 min).
Well, now the oscillation is a little less BUT is definitely still there
Do you have any suggestions of what should i do next?
