why an egr blanking plate
HI I may appear a bit dim here, if you disconnect the vacuum pipe the egr valve wont open so why would I need a blanking plate
If it doesn't fit you need a bigger hammer
Re: why an egr blanking plate
Because it can be stuck open with crud
, a blanking plate is easyer to fit than removing the EGR to clean it
2006 BMW e61 535d m-sport
run's for cover
