P0402: Permanent Fault: EGR Measured Airflow Higher Than Recommended
Cleared the fault, reappears within a few seconds of the engine starting.
Correct me if I'm wrong, it's referring to higher than recommended airflow through the MAF, so this means the EGR is more "closed" than it should be? The vac system appears fine, and I've tried switching the EGR E/V for a known good one - no improvement.
The two things that spring to mind are 1) a leak in the EGR circuit or 2) EGR valve stuck closed. On visual inspection I can't see any leaks at the EGR outlet or inlet. Is there any way of checking whether the valve is opening and closing properly?
Any other potential causes for this?
