HDI 90 Alternator belt
Need to do the Alternator belt and trying to source a good deal. Now Pug themselves have suggested the length of the belt varies depending as to whether I have a Delta or a Sanden(sp?) compressor, so just wondered what others experience is here, as no other supplier seems to ask! Does it matter??
Re: HDI 90 Alternator belt
Sanden and what now? The difference is very slight but apparently it does make a difference. Sanden and Dolphin - viewtopic.php?f=3&t=15634&p=151849&hilit=sanden#p151849
You could just take the numbers off of your old belt and a decent factors should be able to take it from there.
Sanden and what now? Dolphin? :-p Yes it is about 10mm apparently but worth getting the right part IMO. Looks like mine is a Delphi so now I know I will try to find a kit off the bay...
Thanks for your help!
I always seem to have difficulty getting the right belts, I have taken to finding the length by wrapping a piece of string around the route and measuring it...or you could of course measure the one you have if no writing is visible.
