turbo and fuel pump
Posted: Thu Feb 22, 2007 8:05 pm
by andybee
has any turn up the turbo and fuel pump and on what motor?
Posted: Thu Feb 22, 2007 8:57 pm
by jameslxdt
you need the cut off the immobilliser stop solenoid shield to get to the fuel screw, which involves removing the pump, so its not as easy to tune as a 306 1.9td
Posted: Fri Feb 23, 2007 12:09 pm
by andybee
ok the 306 lads are going to have aplay with it. the 306 were very easy to do .
Re: turbo and fuel pump
Posted: Fri Feb 23, 2007 12:22 pm
by niz406
andybee wrote:has any turn up the turbo and fuel pump and on what motor?
Turbo Yes Fuel no need... providing you do not exceed 1 bar (100kpa) This is the ECU's max boost limit over this results in overboost protection. Fuel / Spark Cut! actually fully diverts all boost pressure to the WCS wastegate control solinoid.
If you want to exceed 1 bar then a crude way is FSE PBV with a penumatic Fuel Cut Defencer.. if you get the PBV buy the guage so you can tweak the max fuel rail pressure. You could also use some larger bosch injectors... from a Punto GT or similar.. 330cc as long as the injectors are rated around the 16 Ohm mark.
Posted: Fri Feb 23, 2007 10:40 pm
by jameslxdt
niz you donut, hes on about 1.9td not the 2.0 petrol turbo, we all know the 1.9 td is so much better than the petrol turbo
Posted: Sun Feb 25, 2007 7:46 pm
by niz406
jameslxdt wrote:niz you donut, hes on about 1.9td not the 2.0 petrol turbo, we all know the 1.9 td is so much better than the petrol turbo
As homer would say to this:
DOH!
Posted: Sun Feb 25, 2007 7:51 pm
by jameslxdt
niz you are back, did you get my pm
