air doser
Posted: Fri Jun 13, 2014 1:22 pm
by binnzy
Hi can anybody tell me what an air doser is and what does it do
Re: air doser
Posted: Fri Jun 13, 2014 1:56 pm
by Doggy
It's a throttle flap that restricts air flow into your inlet manifold to ensure sufficient exhaust gas is recycled during idling, overrun and other periods of light engine loading. It is part of the egr system and works in conjunction with, but not necessarily at exactly the same as the egr valve.
Re: air doser
Posted: Fri Jun 13, 2014 2:16 pm
It also has another function where it slams shut on engine shut down to reduce that ~~shudder~~
Re: air doser
Posted: Fri Jun 13, 2014 6:02 pm
Later 2.0 HDis didn't get them
Re: air doser
Posted: Fri Jun 13, 2014 7:04 pm
by binnzy
thanks for the replies, if it's part of the egr do I need to get rid of it when I get the egr mapped out
Re: air doser
Posted: Fri Jun 13, 2014 8:21 pm
by GingerMagic
It works with the EGR, but if you get rid of/blank off the EGR you may as well lose the doser.
You don't need to, it will just be unplugged from the vacuum system.
You could replace it with the pipework from a 2003/2004 model which bypasses the air-doser for a neater engine bay if you like.
Re: air doser
Posted: Sat Jun 14, 2014 8:51 am
by binnzy
Thanks I'ii see if I can find the pipe work at the local breakers
Re: air doser
Posted: Sat Jun 14, 2014 9:07 am
by Doggy
This shows the alternatives
Re: air doser
Posted: Sun Jun 15, 2014 4:50 pm
by binnzy
Helpful thanks
