A Aaron what's this loose hose??!
chasesdragons
Post by chasesdragons »
Help pls.
Car is a 1998 406 1.9td.
Uberderv
Re: A Aaron what's this loose hose??!
Post by Uberderv »
Water drain tube. If you follow it to the fuel filter housing you will see a little screw cap. You undo this to drain it :)
Yes, normally this tube just hangs out the bottom of the engine bay - out of sight out of mind....
chasesdragons
Oh thank you. I was looking everywhere for a potential plug in point and sat there sucking on it to check for engine changes like a plum.
