Hi Ben, I have been using 2 stroke in both my 2.2hdi and the wifes Picasso.
Joost on the toupe club was saying modern diesel fuel is lacking the necessary chemicals to lubricate the pump and the 2 stroke mineral oil replaces it.
I am still a relatively new user but Doggy is on his 6th tank at least...
I would say its worth a punt at the price.
Kelv
2 stroke oil mixed with diesel
Re: 2 stroke oil mixed with diesel
IIRC, I'm nearing the end of my 10th tankful, (first 'dose' out of bottle no. 4).
I'm convinced it's a good thing and may well be contributing to my consistent 50 mpg average.
You need API TC or JASO FB. I use the red stuff you get in Asda - £5 in store for 1 litre, used to be £3.62 on line, but now it's the same price.
http://direct.asda.com/ASDA-Motorcycle- ... lt,pd.html
I pour in 1/3 bottle, then top up with 65/70 litres of diesel, which is near as dammit 1:200, (333 ml x 200 = 66.7 litres).
- rwb
I believe 'low ash' is what you have to look for, which I presume is part of that specification.
Will be starting this in the 407 from November when I have 12 months data to compare against.
I ran my last 407 on 2-stroke mix and it quietens the engine down a treat it also added about 2-3 mpg to mine so i'm using it on the latest car as well
How long will it be before 2-stroke oil gets really expensive?
Didn't Vegetable Oil go up in price once they realised it was being snapped up rather quickly by motorists?
I'm guessing that by adding this stuff it pays for itself in better mpg? and with the bonus of sweeter running. I hope the injectors don't complain about it although the mix is very light.
- DaiRees
- Site Admin
Yeah, some of my old 4X4 mates were running 50/50 diesel with new veg oil, there was a time you could get 3 litres for 99p or 20l for £4.99 in some cheaper supermarkets. Now it's a lot more expensive, no wonder the price of chips is on the up!!Welly wrote:Didn't Vegetable Oil go up in price once they realised it was being snapped up rather quickly by motorists?
- Rolebama
Veg oil had fuel duty added to the price which is why it shot up. 2-stroke oil already has it built in.
As for its use, no reason not to, but only use the low ash type. (If it doesn't say it on the container, it probably isn't.)
Personally, I advocate Millers Eco stuff as it works out cheaper and is specifically made for the job, although any injector cleaner will do.
As for diesel fuel itself, it is an oil, it will lubricate all the moving parts of the system, and because of the majority of fuel pumped is returned to the tank, everything is always totally immersed in lubricant. Using 2-stroke oil as a lubricant is just a waste of money. One of the things it can do is pick up the muck from the exhaust and clean it out in passing, and it will help to keep the fuel system clean.
1998 2.1 GLX TD
