peugeot 207 auxbelt tensioner.
Hi all.
Thought its worth an ask before ordering any part's.
The aux belt tensioner on my 207 sounds 'a bit moody..
So I've been looking up replacement's on the web..
Euros is showing two options .. just the wheel or the whole thing..
Does the wheel part actually come off..
Full unit is 70 notes and just the wheel. Is 16 quid..
Jasper is doing a service on it .. so I might as well get this aux belt thing sorted..
Thrust bearing as started to sound moody too...looks like I've bought a pup :roll: :cry: :(
jasper5
Re: peugeot 207 auxbelt tensioner.
Post by jasper5 »
lozz wrote:Hi all.
Let me know if I need to take any parts with me.
Cheers mate..
How much can you get ..the tensioners for..
Wouid you have time to fit one.. as well as the service..
Aux belt is brand new.. but the wheel on the tensioner is worn away..
jasper5
Post by jasper5 »
lozz wrote:Cheers mate..
I'll need your reg number.
Do I need to take plugs and air filter?
Oil change has been done?
I picked up all the parts mate.
Plugs.oil.oil filter.cabin filter.air filter.fuel filter.
Tensioner for the aux belt ..
Is 10w 40 oil OK..
Cheers
jasper5
Post by jasper5 »
My supplier has 5w40 fully synthetic listed for your engine.
Ah rite..
They've gave me the wrong oil then., :(
I will buy some more in the morning..
Euro car parts are getting pathetic for giving the correct stuff out..
I will avoid them in future..
jasper5
Post by jasper5 »
Strangely enough Euro Car Parts have 5w40, 10w40, and 5w30 listed for your car so I guess it's your choice :D
Thanks.
Thanks jasper
For servicing the car for us..
Nice to meet you and jaz
Connor said thanks for helping him with that tyre change
I think he learnt something new there.. 8)
jasper5
Post by jasper5 »
lozz wrote:Thanks jasper
No worries :D
Nice to meet you and your family :D
Thanks for rescuing me ....I learned something too...Google maps are completely useless :shock:
Hopefully he'll remember the technique I learned as an apprentice 40 plus years ago :cheesy:
Thanks also for looking after us today.
No problem mate..
The 207 is a lot better., took it out on a good run over the 'tops
Its getting 41.4 mpg before it was around 29 31 I sh
Its still 'hunting a little on first start 'up. I'm not sure what that will be .. an idea's.
I'm thinking 'timing might be out a 'little...
So timing belt change is deffinatly on the card's.
Thanks again ..for today its much appreciated..
jasper5
Post by jasper5 »
I've been asking around about the idling problem you have....people seem to think there may be a problem with the timing connected with the VVTI system on the camshaft or the VVTI sloanoid needs cleaning....could still be something to do with timing belt.
People tell me setting the timing on the camshaft can be very, very tricky :shock:
Thanks .
I've bought a Haynes manual.. its very very 'vague, not much 'info in there for this engine.
There is one small diagram of the 'cams. One is locked off with a 5mm drill bit. Inlet cam.
And the other one.. a 8 mm drill 'bit' exhaust cam.
This engine is alien to me so 'I'm lost.
But I'd presume if its got a phase sensor of some sort ..it 'd bring on the Engine management light if it was out on timing..
I'might be miles out here tho..
I found something on the internet ...where someone's had a similar problem and they've used planet to do a throttle-relearn..
jasper5
Post by jasper5 »
lozz wrote:Thanks .
I see...maybe we could try the planet throttle-relearn sometime.
The timing belt book makes the job look fairly straightforward.
