Mystery EML
jonsowman
Mystery EML
Post by jonsowman »
So the EML popped up on the estate a while back. Only just got round to scanning it: http://imgur.com/OtQsfHy
Any ideas as to which is the most likely suspect? I know it's not the Preheat Relay, and I suspect not the EGR either? :?
gumby6371
Re: Mystery EML
Post by gumby6371 »
EGR stuck open would give a higher flow of (manky) air?
Looks like you may also have a dirty TPS?
jonsowman
Re: Mystery EML
Post by jonsowman »
I didn't think EGR flow too high/low caused the EML though? I think there is an EGR fault there, but since the MOT is coming up, priority is sorting the EML.
Wonder if the TPS fault could be causing it?
For now, I've cleared all the faults and the EML hasn't come back...
Re: Mystery EML
It is an Intermittent fault Jon, so maybe there was a glitch one day, maybe a longer than usual cranking to start the car to confuse the ' easily spooked' electrics or whatever - hopefully just a hiccup... :wink:
I do remember Alex changing his TPS one day and forgetting to plug it back in before starting the car - his EML stayed on for decades.... Not something to trifle with if there is an MOT creeping up on you.
jasper5
Re: Mystery EML
Post by jasper5 »
Having the EML light on is NOT a mot failure.
Re: Mystery EML
See what comes back, Jon.
The pre-post heating one's been there forever - won't cause the EML
The egr message is what you get if you blank it and don't change the software, (maybe it's partially blocked itself) - won't cause the EML
The accelerator pedal signal is the favourite culprit for the EML - I wouldn't worry unless it returns
The upstream cat temp sensor gets ignored anyway and normally displays 752.0 degrees. :? When we removed the FAP, we found the plug disconnected (brown 2-pin plug, somewhere under the servo). Maybe it's fallen out again?
jonsowman
Re: Mystery EML
Post by jonsowman »
Thanks guys. Eric - I know the plug relay one has been there forever, not worried about that. I'll check the temperature sensor plug though.
Will keep an eye out for the EML coming back and report back.
I do have a spare TPS which might work, or in the worst case, I'll swap the one in from the Coupe to test.
jasper - I didn't know that, thanks for clarifying :)
rwb
Re: Mystery EML
Post by rwb »
Intermittent = clear them and see if any come back.
Is the EGR blanked? (It should be!)
