breather filter
GAZ-23
breather filter
Post by GAZ-23 »
hi dose any one no what the breather filters do and what size would i need cheers :!:
niz406
Admin <BR>Turbo God
Post by niz406 »
Which filter exactly and what engine??? Pics ???
Most of the breather filters are to catch any oil to stop it entering the inlet tract, the breathers are for crankcase ventilation to prevent crankcase pressure build up and gasket / component failure ! :D
Niz406
jameslxdt
Post by jameslxdt »
niz406 wrote: gasket / component failure ! :D
you know all to well about this niz
how long till you blow this head gasket? :cheesy:
niz406
Admin <BR>Turbo God
Post by niz406 »
TBH James... I think its already gone.... got to check it tomorrow... LMFAO :lol: :lol: :lol:
Although everything on the head and breather system is new.... filter, amplifier filter, oil fill/catch tank etc... Not loosing any coolant, but there is some oil burning turbo side of the block and the water feed hose is under pressure which would indicate failure.... could be water pump though so will need to check both turbo and water pump out ! :D
Possibly going to view a 194hp V6 Saloon tomorrow, as a run around until I can sort the Turbo out :lol:
Niz406
jameslxdt
Post by jameslxdt »
niz406 wrote: Possibly going to view a 194hp V6 Saloon tomorrow, as a run around until I can sort the Turbo out :lol:
you lucky fooker :x
GAZ-23
breather filter
Post by GAZ-23 »
my engine is a 1.8 16v i seen a k&n breather filter on ebay for £15 but not sure weather it will improve it or not
niz406
Admin <BR>Turbo God
Post by niz406 »
you lucky fooker :x
V6 was sold the first day it was advertised so I missed out there !
GAZ - are you talking air filter and not breather filter then?
Niz406
