turbo types.
Ares
turbo types.
Post by Ares »
Bare with me as i know there are probably some topics with this info but i only managed to find out some.
I know that in 406 petrol tubby 108kw is Garret T25.
Also i found on some of the topics here that its possible to mount some Nissan turbos.
Is there any other turbo,bigger than current T25 possible to mount from other french vehicles.
Prices of them here are going skyrocket and i was thinking of buying second hand turbo and get it repaired if neccesary cuz that aint so pricey.
Was looking at some data of 2.2 hdi,maybe even some Iveco,VW types but i cant find an certain info about it.
Oh yes,i forgot to mention you guys,i bought a 406 Coupe :cheesy:
PeterN
Re: turbo types.
Post by PeterN »
The problem with fitting a larger turbo is that you are going to reduce the low down boost - unless you use a variable vane type, although if its a petrol engine it might not matter so much but it will introduce some lag.
Ares
Re: turbo types.
Post by Ares »
Thanks Peter,so far plan is to repair the original one but this one cant handle some boost tuning so i asked.
