Bosch fuel filter housing
hi all i have bosch fuel filter dhouling and were the bleed screw is it has a litte pipe before it. its dripping a bit of derv on tick over is this normal
- Captain Jack
Re: Bosch fuel filter housing
I never saw mine drip. There's a plastic nut thing at the bottom - make sure it's tightened.
it dont budge either way
- Captain Jack
Where is it leaking from? The tube itself?
So you got the drain screw then just before that there is a tiny pipe pointing down its the little bit pipe that's pointing down just before the screw
