Some of you may know back in August I had to scrap my old 406
Here's the problem.
Early November I had the coolant light come on so topped it up and ever since it's pressurising... Had a sniff test done before Christmas that was clear so tried a thermostat change (Bottom hose gets hot, top hose luke warm)... Only done short journeys after that up until Boxing day... Still pressurising up until then.
We had boooked a holiday for Dec 27th and paid for so we went... Lost about a coffee cup full of coolant on a 90 mile trip and probably about the same driving around for the week.... Drove home after New Year and lost about a litre of coolant
All this time I've noticed no leaks so yesterday a good friend of mine borrowed a coolant pressure tester and we gave it a try.. Everything holding fine with no leaks or escaping air... Mate suggested running it without the thermostat and sure enough it was stuck closed (Looks like it could be from the k-seal type stuff put in when they done the sniff test that I forgot to mention)
Running without the thermo in place I was kind of optimistic but the short 5 mile drive from his house saw it pressurised again with the new cap sounding like hissing Sid
Where now? Flush the whole lot out and start from scratch? Maybe the rad is blocked or one of the pipes?.... Thanks in advance lads.
