Hi everyone. My 2000 hdi 90 estate has a broken low pressure in tank pump. It is a Bosch 0580303005. I have seen plenty on ebay for my model but the numbers are different. Does anyone know if there was a replacement pump and what number it should be?
Thanks.
low pressure diesel pump
Re: low pressure diesel pump
Hi, this list was pulled from an ebay ad so please double check before buying but should give you some guidance.
0580303005 BOSCH
0580303026 BOSCH
96304560 CITROEN
9630456080 CITROEN
96305857 CITROEN
96378122 CITROEN
1525Z2 CITROEN
1525C2 CITROEN
1525Z2 CITROEN/PEUGEOT
9630456080 CITROEN/PEUGEOT
96305857 CITROEN/PEUGEOT
1525C2 CITROEN/PEUGEOT
775097 ER
7301309 MARWAL
96378122 PEUGEOT
1525Z2 PEUGEOT
1525C2 PEUGEOT
9630456080 PEUGEOT
96305857 PEUGEOT
96304560 PEUGEOT
700468940 PIERBURG
0580303005 BOSCH
0580303026 BOSCH
96304560 CITROEN
9630456080 CITROEN
96305857 CITROEN
96378122 CITROEN
1525Z2 CITROEN
1525C2 CITROEN
775097 ER
7301309 MARWAL
96378122 PEUGEOT
1525Z2 PEUGEOT
1525C2 PEUGEOT
9630456080 PEUGEOT
96305857 PEUGEOT
96304560 PEUGEOT
700468940 PIERBURG
2003 406 2.2HDi SE Estate Manual - Sold
I have one that came from a C5, pump looks the same but housing is different.
Thanks for the info.
Apparantly there are two types. One has a wider neck. Mine is the smaller of the two.
