high revving at start up when cold
tonko007
Post by tonko007 »
Hi all I have a 406 2.2.hdi 2002 and it is revving high on start up cor perhaps a couple of minutes then goes to normal idle anybody know what I can do sort it out before it gets any worse thanks in advance
peugeot30v6
Re: high revving at start up when cold
Post by peugeot30v6 »
Is it just when cold and what rpm does it rev to?
Sent from my iPhone using Tapatalk
tonko007
Post by tonko007 »
Hi there it revs to approx 1300rpm and only when cold once you move off its fine or blip the accelerator a tiny bit
peugeot30v6
That's just the car heating up and getting to temperature faster when cold, any higher than 1800rpm and you might have a problem but other than that it should be fine
MIne only idles at about 900 when cold. Something odd going on here.
If it 'thinks' the car's moving, the idle speed is increased to make pulling away easier, but should drop back to normal with no road speed.
Are you getting any other unusual behaviour?
peugeot30v6
Ohh, did not see HDI, like Doggy said it is unusual for a diesel to do that. My V6 does that to heat up but Diesels shouldn't. Might want to get that checked out. Maybe PP2000 would identify the problem
This used to happen on the 110's.
'Wiggle' the multi-pin connector on the throttle position sensor (the thing at the engine-end of the throttle cable) and it should hopefully settle down.
As Welly says , same happened to me ....
I was thinking it may be the throttle cable clip on a bit tight, it does make the revs go a bit funny... :wink:
tonko007
Post by tonko007 »
I have pp2000 and is saying accelerator position sensor fault do I need a new one
Try releasing the clip on the outer cover of the throttle cable at the TPS, checking the measured value is 0%, clearing the fault and checking if you can get a smooth progression of values up to maximum, (I can't remember if it's 99 or 100%).
If you can't get the right values, I believe there are a couple of posts about stripping and cleaning the sensor, (by rwb perhaps)?
tonko007
Post by tonko007 »
Cheers guys if you ever see me about I will buy you a pint thanks guys
