Hi,
I have a 406 hdi with a broken drive belt. It came off shredded and wrapped around one pulley. The belt that came off was a 6pk1750. (according to the markings on the belt)
I got a 6pk1740 which I believe is the right one for a car with the sanden ac unit.
When I try to put the belt on its too loose! no matter what I do. Its too loose by a lot. 2-4 inches.
I believe it is on right and someone else has looked as this as well. Its over the cs pulley, under the auto tensioner, over and under the ps pulley, looped over the eccentric idler, back over the alternator wheel and under the ac pulley.
I cannot figure this out. There is far too much for the eccentric idler pulley to take up. I am stumped!! or I am stupid.
It almost as if a pulley/wheel is missing?
The auto tensioner is fully on and is working fine. There is nothing loose.
Can anyone assist? I am on the verge of getting a smaller belt even though ALL providers state a 6pk1740 and 6pk1750 is the one for the 406 hdi with ac and the belt that came off was a 6pk1750.
Its driving me mad.
Thanks in advance
Barry
Drive Belt 406 HDI 2002
Re: Drive Belt 406 HDI 2002
Hi, welcome to the forum!
You could try having a look at Farmerpug's excellent video of a crankshaft pulley replacement see if that helps....viewtopic.php?f=1&t=19174&p=190348&hili ... di#p190348
There is a diagram in it and how to fit the belt.
There is another belt routing diagram somewhere on the forum, use the search function and take a look around.
Here...viewtopic.php?f=10&t=9948
Hi there. Umm, 2.0 or 2.2? I thinking the numbers are correct for a 2.0 but...
(Courtesy* Haynes BoL)
