'Pug 207 Aunti-poloution'
'Sorry not 406 related:
Any one clue'd up on 'Lambda sensor's on here,?
This Might seem' strange,
(Ive had-Fault code: P0135. Aunti-poloution showing on MFD, (fault code: retrieved from my trusty Basic Code reader,not PP2000..so there wasn't much
info to go off,or other option's.)
'Swapped out the lambda sensor, 4times, now, 1st one..was one that came with A cat convertor ibought off ebay= low mileage 10plate breaker,
After 15miles, eml came on,
X 2 Euro car parts, NTK not NGK. chinnesse? :?
Swapped again with another,, Brandnew one, Expensive item, :(
Same, 15-20 miles. eml back on.,
* next step was -strip the loom back, all good there=no Breaks or water ingress,
Heres the weird part, itook the pre cat lambda-sensor back out and replaced it with one that's supposed to be fitted after the cat.,(Blue conector,)
front one is Green, no problem, alls well.
the Lambda =pre cat is heated,
the lambda sensor=after cat isn't,
will it do any damage..running on a wrong sensor?
The end is nigh for this car now, just waiting for the Mot And tax to run down,(September) and its going to the scrapyard,.
Re: 'Pug 207 Aunti-poloution'
Fixed, or atleast for now,
garage found the Ecu to be faulty, came back with large repair bill, :(
Time to get rid whilst the going is good, replace with something JAP me thinks, *Mitsubishi,
