Odd clutch behaviour
crazy88
Post by crazy88 »
Hi guys & gals,
Hope you can help with a strange issue with the pug. Had a new luk clutch kit fitted around 15k ago been fine up till recently. Noticed a few days ago when cruising with clutch engaged if I slightly depress the pedal speed picks up and seems to get better drive. Is this normal behaviour or if not do you have any suggestions on how to diagnose if there's a problem in the system somewhere?
cheers
fattail95
Re: Odd clutch behaviour
Post by fattail95 »
Hi there,
The different behaviour you are experiencing is due to the clutch switch, it is used to deduce whether your foot is on the clutch or not, I believe with the clutch depressed the ECU allows the engine to rev much more quickly and more freely (so you can perform rev-match downshifts for example). You can unplug it and it will run happily without it (as long as you don't have/use cruise control). I believe members have reported a more aggressive/sharp thorottle response but in my experience it removes a lot of the refinement of the car. Acceleration becomes jolty as you press the throttle, and it makes the car feel less damped particularly in the diesel models.
Hope that helps!
Ben
You must have an Hdi90..!!
As Ben says, its to aid a smoother gear change. If you were to unplug the brown switch above the clutch pedal, you will have increased performance but a bit spluttery when changing gear on a cold engine, but you get used to the slightly less refined-ability-ness. I unplugged mine and never looked back... :cheesy:
If you have cruise control, then please don't touch the switch....!!!
This is unrelated to the new clutch, by the way.
crazy88
Post by crazy88 »
Thanks both for taking the time to respond. As you suggested I've disconnected the switch this afternoon and problems solved! Cheers for the help!
