I've had my EGR blanked off at the intake manifold end for around a year now with no issues, but now the EGR valve itself has failed and is spilling exhaust gas into the engine bay which is no good. I'm going to remove the EGR system altogether (including the heat exhanger) as well as all the pipework and seal each end up with a heavy duty blanking plate.
Once I've removed the heat exchanger I will need to join the two water pipes, but does anyone know the ID for these pipes? I got the digital calipers out and measured at ~30mm but thats OD and I don't know the rubbers thichness. And question two, what type of joiner should I use to bridge the hoses?
Servicebox diagram:
Best regards
Ben
