Good old EML's
Posted: Sun Jan 17, 2016 6:40 pm
Chasing around loads since getting this 2.2 HDI ******, sorted the Diaphragm which was leaking and the end was broken off, then that seemed to work for a few miles then the EML again with the DPF blockage so cleaned that out until it get's remapped as it will be removed, Again fine for a while until we got on the motorway for a couple of miles and yep it came back on. But since I cleaned the DPF out on the way home we managed a good 45 minutes of no limp mode
But the brakes would once in a blue moon have no servo assistance, so today I checked it out, the servo seems to be leaking, you cannot hear anything thou as with it connected the old Diaphragm does not fully move until you block the end of the vac supply to the servo off which hopefully points to the servo loosing some vac from time to time so causing random issues with the system and bringing on the EML and bloody Limp mode
Sounds feasible ?
Sounds feasible ?
