2.2 hdi goes into limp mode at high speed
Posted: Mon May 09, 2016 12:11 pm
by Ammar786
hi fellas as the title says my car goes into limp mode on the motorway at high speed.
does not doit around town or in low gears which is why im confused
has anyone had this before or knows of the cause
thanks
Re: 2.2 hdi goes into limp mode at high speed
Posted: Mon May 09, 2016 2:18 pm
Is the car remapped, defapped or anything? Can you get access to Peugeot Planet?
Posted: Mon May 09, 2016 3:20 pm
by Ammar786
Yes the car is remapped and defapped
Ive had new swirl diaphram on and cleaned the vnt turbo
And no i do not have access to peugeot planet
Posted: Sun May 15, 2016 9:14 pm
by Ammar786
Right so im still having this issue,
im driving on the moterway put my foot down and after about 5 secs it goes in limp mode.
turn the car off for 15 secs and start again and all is fine till i do the same thing on the motorway.
It has got me really baffled as it never cuts out at full throttle in 1st 2nd or 3rd. only cuts out in 4th and 5th and thats on at igh speeds too
got the codes read today
p2035
p2045
one is overboost and one is underboost.
can anyone help me out at all
thanks
Posted: Sun May 15, 2016 9:32 pm
by jonsowman
Vacuum leak. Potential boost leak as well.
Posted: Sun May 15, 2016 10:02 pm
by Ammar786
Ive replaced all the vacuum pipes and simplified my vacuum system
ive also checked the turbo vanes which are fine and move freely
Posted: Sun May 15, 2016 10:07 pm
by jonsowman
Remaining suspects are the actuators and electrovalves still remaining in the system.
Particularly, check the swirl actuator, the swirl EV and the turbo EV. Even if everything appears to work OK they can still have small leaks which will cause the overboosting at high load.
Under rare circumstances it could be the MAP sensor (pipe from the intercooler) but this is not very often the case.
Underboost could be a boost leak but is more likely to be a side-effect of the vacuum leak.
Posted: Mon May 16, 2016 5:38 am
by barbaren
I could very likely be a worn injector. You need to get the faultcodes read out. You will not get anywhere be guessing.
Posted: Mon May 16, 2016 5:32 pm
by Ammar786
the swirl actuator is brand new i just replaced it about 2 weeks ago
the next on my list the EVs and ill see if it helps
thanks
Posted: Mon May 16, 2016 5:37 pm
I'd better admit to being almost completely ignorant but... Isn't this what happened to CJ (I think it was) when he stuffed a generic map on his car?
Posted: Tue May 17, 2016 2:21 am
by Ammar786
Well im tempted to put the original map on my car and see how she runs
Posted: Tue May 17, 2016 6:32 am
by GingerMagic
Have you checked the restrictors?
When my car had a P0238 last year, and a P0235 this year it was down to a blockage.
The restrictors are the 3 way and 2 way fittings on the vac pump and the servo - the hole is tiny and easy to block.
Posted: Wed May 18, 2016 1:17 pm
by Ammar786
ive checked the restrictors and cleaned them out
so i know there clean
how would i know if its a faulty injector?
