urgent advice needed
daddykins2
Post by daddykins2 »
i have a 406 (110) hdi with bosch hdi pump, and it`s broken.
question is, i have obtained a siemens hdi pump, will it work with my bosch ecu,, the plugs look the same,,as do the pipe`s,,,, does anyone know ?
the truth is out there
jameslxdt
Post by jameslxdt »
the siemens pump wont work as it was only used on the HDi 90 and it never had a lift pump, the rail injectors, and fuel lines will also be different
daddykins2
ok
thanks for the info... shame,, now i have a complete engine to sell
jameslxdt
Post by jameslxdt »
does it have a loom and ecu?
daddykins2
complete
yes it hase everything gearbox.alternator.starter everything.. it is a 02 plate 406 HDI (90) td
72k from a burnt out estate (rear end fire) i had the doors,bonnet,bumper as they was the same colour as mine
jameslxdt
Post by jameslxdt »
how much you looking for it?
daddykins2
just the engine or the gearbox as well.. make me an offer,, they are just sat there.. i have pics of them,, i was going to put them on ebay, but they wont be too deer
jameslxdt
Post by jameslxdt »
i would want the gearbox as well, i was planning on doing a HDi conversion to my 406 but im not sure if its worth the effort, ive no idea of how much its worth, how about £200? would i be able to have the chip out of the key as well (for the immobiliser)
daddykins2
the price is ok.. but i hav`nt the key/chip. everything else yes. wiring harness all disconected,not ripped out, ecu, all hoses, and inlet`s covered to stop dirt getting in,,like i said totaly complete (ecxept key ) sorry
jameslxdt
Post by jameslxdt »
do you know the mileage, any service history?
daddykins2
the mileage was 72.874 i dont know about the history, it came into our yard on a trailer.
jameslxdt
Post by jameslxdt »
does the engine even run?
daddykins2
yes the engine purred like a kitten,, all the gears there, it`s only the fact that my 90, and my 110 are bosch pumps,, otherwise i would keep the engine
jameslxdt
Post by jameslxdt »
have you had any other interest in the engine? as i want it, but will have to see just how possible converting it would be, as i will need other bits too, like the accelerator pedal sensor, engine mounts etc.
daddykins2
i have the pedal sensor,, and i can help with any other parts you need. i work for a car breakers so spares are not a problem for me
