air con pipes
binnzy
air con pipes
Post by binnzy »
Hi has anyone got any tips for removing the air con pipes from the condenser mine seem to be seized in.
thanks.
If it doesn't fit you need a bigger hammer
barbaren
Re: air con pipes
Post by barbaren »
That is a job for a prof. It is filled with Freon which is a toxic gas.
Sent from my iPhone using Tapatalk
binnzy
Re: air con pipes
Post by binnzy »
No gas in it, leaking, which is why I'm fitting a new one
Re: air con pipes
Recently did mine. viewtopic.php?f=3&t=24212
Managed to remove the upper pipe, but snapped the end off the lower one.
Then snapped the ends of 3 more in the scrappy, before forking out for a new OE pipe, (£70+).
Best of luck.
