Hdi 90 Gear Linkage Rods or Cables?
Posted: Fri Jun 10, 2016 6:43 pm
Hello, having a similar problem to a previous post back in 2010: viewtopic.php?f=1&t=10669&start=0
My gear lever is just flapping from side to side & I can only select 1st gear. Thinking this is also a linkage problem.
Just wondering if anyone could confirm any of the following:
Does the Hdi 90 HP have gear linkage rods or cables?
Is the correct engine code for the Hdi 90hp version – DW10TD and correct transmission code: BE4/5.
I have the Haynes manual for the 406 which only covers models from 1999 to 2002. The manual states: There is ‘a selector rod mechanism on BE3/5 transmission and a selector cable on the BE4/5 and ML5T units’
I just noticed that on the previous post back in 2010 Steve_Earwig states:
^On the HDi 110 (ML5T) it is cables but on the HDi 90 (BE4R) it's rods. Or rather 1 rod, with lots of little linkages which'll have plenty of scope for wearing out and/or falling off".
Seems to be at odds with the Haynes manual? if the Hdi 90 is BE4/5 transmission ???
Also would anyone consider using parts from a scrapped car for this type of issue, or better to go with new parts only for this?
Could it be anything else causing a loose gear lever?
Thanks in advance for any replies, much appreciated.
