clutch pedal snatchy
pjb0150
Post by pjb0150 »
1.9td ,, just bourght it ,,,,but clutch pedal is not smooth its sticky ,,,is it cable can it be lubed and what with tia
Re: clutch pedal snatchy
It's a cable, can't help with the rest, sorry.
Someone intelligent should be along soon......
As far as I remember a 1.9 is cable (Service Box is down again, down again, down again, Service Box is down again, what a piece of crap). from what I remember the cable should have a nylon lining which, once worn out, means the cable is scrap, lubricant will only work for a short while. I suppose it might be helpful to lubricate it, just so you know if it's the problem. Something with PTFE if available, or maybe molybdenum, but it won't last long.
