Clutch
barbaren
Clutch
Post by barbaren »
Hi
My clutch is engaging right away. Not slipping or anything. Was just wondering if it could be air. Or is the clutch ending its life?
Want to ask before starting with anything.
Sent from my iPhone using Tapatalk
dirtydirtydiesel
Re: Clutch
Post by dirtydirtydiesel »
Nearly all 406 clutches engage quite close to the floor,
To check if it's worn-out stick it in top gear at about 1500rpm & floor it.
If the rev's rise faster than the road speed then it's slipping & worn-out.
Mine would shoot up when it hit 2000rpm but I did have a caravan on the back.
barbaren
Re: Clutch
Post by barbaren »
dirtydirtydiesel wrote:Nearly all 406 clutches engage quite close to the floor,
It is not worn as such. It's just that I just have to touch the pedal. Maybe one inch down, from the very top, and it's engaging. Dont know how old the clutch is. This is my first Peugeot so Im not that familiar with it yet. I have changed the rear brakecalipers. Could that maybe cause air in the clutch line?
Re: Clutch
Yeah my clutch engaged at top of the pedal travel on both my 406s. It's a common "issue", which is more of a characteristic.
barbaren
Re: Clutch
Post by barbaren »
Captain Jack wrote:Yeah my clutch engaged at top of the pedal travel on both my 406s. It's a common "issue", which is more of a characteristic.
thx that calmes Me.
