ANY HELP WILL BE GREATLY APPRECIATED.....
cant figure out where im supposed to check, or even top up the oil on my slushmatic box....problem is I cant tell if its an AL4 or otherwise. getting a snap change from 2nd to 3rd so think fluid is getting low..(I hope), so figured this was best course to try.
if anyone can advise where the fill point and drainoff is and how easy i can access them, then my ears are open....
thanks guys.
AUTOMATIC GEARBOX OIL CHANGE
"That'll do pug.....that'll do...."
406 GTX Auto 2.0 99 "V".....aka Vader..
drain all the oil, change gasket on plug. Half way up on the gearbox there is another plug. Remove it and fill until oil comes out. Job done.Drewnn3 wrote:ANY HELP WILL BE GREATLY APPRECIATED.....
thanks guys.
However you might want to change the filter also. I would. This means you have to take the bottom cover of.
Sent from my iPad using Tapatalk
