No power when engine is cold
barbaren
Post by barbaren »
Hi guys
After correcting a lot of small issues on one of the best cars I've ever had. 2004 406 hdi estate.
There is however still one thing that I dont get. I have read tons of pages on the topic. Pretty much all of them had a different solution. So now I'm asking you guys.
When the engine is cold. It hardly takes the gas at all.
When the temp. reaches 70 C everything is back to normal.
All filters are new, oil is new. Additives used regulary.
Any ideas?
Sent from my iPad using Tapatalk
PeterN
Re: No power when engine is cold
Post by PeterN »
You always will get less power and use more fuel on a cold engine but the power loss is not normally all that noticable. The only thing I can suggest is a faulty MAF sensor as that measures the volume and temperature of the incoming air, try disconnecting the plug and see if it makes any difference.
barbaren
Post by barbaren »
Thx for the answer Peter.
Have disconnected the MAF. It runs much better, not perfect but better. But it is only an issue when engine is cold, not when temp is over 70.
Can the MAF sensor go partially bad?
Yes.
Inside the MAF is 3 different points for 3 different types of information.
Air temperature, air mix, and air speed (I think)
If the MAF is disconnected then the ECU uses default information already stored.
barbaren
Post by barbaren »
Thx will order a new one right away. :)
It may not be your problem, but if the car improves when it's unplugged then no harm done I guess.
MAFs are expensive, keep your eye our for special offer weekend deals from GSF or Eurocarparts....
trufflehunt
Post by trufflehunt »
barbaren wrote:Thx will order a new one right away. :)
What I'd do would be to buy some MAF cleaner, and apply that.
If that doesn't work, I'd buy on a well known auction site, a good second hand
genuine ( Siemens, as I recall) MAF. Steer clear of the cheap brand new ones.
From China.
2006 Toyota Yaris 1.0 T3
1993 Mazda MX5 Mk1 1.6
barbaren
Post by barbaren »
From China.
I'll second this, don't even consider the cheap eBay MAF's, they are utter shite and will feed the ECU very inaccurate data - sometimes it will perform worse with the cheap MAF connected than with none at all! May also be worth verifying that the coolant temperature sensor is functioning correctly, it is one of the engines primary sensors and if it's duff may be telling the ECU that the engine is warm when it's not, thus injecting more/less fuel than is actually required.
I dont think that maf cleaner will do much good in my case, since it is only when outside temp. is low, but will give it a go. New original sensor ordered, pretty costly but what the heck. Know all about the cheap sh*t from China, had A Mondeo begore this one, and tried some of the cheap parts from China. I guess learning is a lifelong process.
By the way coolant sensor brand new also.
But thx for all the input.
PeterN
Post by PeterN »
I have used a second hand one quite successfully, as they don't very often fail the chances are that any car that's being broken will have a good one.
I used carburetor cleaner to clean mine but be careful not to touch the internals as they are very fragile.
barbaren
Post by barbaren »
PeterN wrote:I have used a second hand one quite successfully, as they don't very often fail the chances are that any car that's being broken will have a good one.
just looked at mine and it is most certainly faulty, one of the 2 thin wires is totally eroded. Disintegrated totally from the spray from the brakecleaner can.
PeterN
Post by PeterN »
Yep, you need a replacement.
dirtydirtydiesel
Post by dirtydirtydiesel »
Just my two penith worth, maf's should be considered as a consumable item,
By the time they've had 100k of air sucked through them there past there best,
Allways if you can afford it use a new genuine one, a second hand one maybe an improvement but
New is allways best, depends what you want from your car :roll:
barbaren
Post by barbaren »
dirtydirtydiesel wrote:Just my two penith worth, maf's should be considered as a consumable item,
agree
barbaren
Post by barbaren »
Changed maf :) silky smooooth even when cold.
Thx for the help guys
