Injectors
Posted: Thu Dec 29, 2016 11:42 am
Ok, so I think I might have an injector issue. Idle is a little lumpy unless it engine is very very warm, and when not quite warm revs between idle and 1300rpm vibrate quite bad. Fuel economy also seems to be quite bad, but not all the time.
Did a bit run down to London and back, averaging about 33-35mpg but occasionally flicking back up to normal 44-45mpg at 80mph. Power seems a bit down too.
OBD scan shows injector correlation way off on one injector and varied on all of them.
If i can get a set cheap enough at the scrappie i'm just going to change em all.
So question is, can I use injectors from other HDI engines (as long as they are Bosch) or do I have to get them from another 110hp 406?
Its getting hard to find a 406 with low miles on at the scrap yard so was thinking a late model 307 or Focus, does it need to be a 2.0l engine or are the 1.6l the same? If I get them from a higher power engine ie: 136hp 407 etc... will there be any benefit? Do I need to remap them?
Sorry for so many questions!
