Gear oil fill plug?
Puggers
Gear oil fill plug?
Post by Puggers »
Is this the filler plug for the transmisjon?
Picture taken at the rear of air filter.
Puggers
Re: Gear oil fill plug?
Post by Puggers »
...and why is it so dirty of oil?
Is it a breather?
dirtydirtydiesel
Post by dirtydirtydiesel »
Looks about right, not 100% from the poor picture & dirt :wink:
You want to use the gearbox breather,
It's a black plastic screw in plug on the top of the gearbox with a clip on black plastic cap.
It will want cleaning before you pull the cap off,
It is located on the top of the gearbox underneath the air box (on a diesel anyway)
If you have drained it, nock 200 mls off the capacity, due to oil trapped inside the gearbox.
On the later diesel engines there's no level hole :roll: , so you have to drain it & refill with the correct amount :wink:
The reason I said to drop 200 ml off is because when I replaced my clutch I removed the gearbox having drained it,
Only to find another 200 mls in when the box was tipped up :?
The capacity on the diesel box is 2Ltrs
Hope this is of some help DDD :)
