Hdi90 clutch upgrade
Posted: Mon May 01, 2017 10:12 pm
by piglet
Think the clutch might be slipping, not surprising at 110K with a remap 18 months ago.
Will the 110 clutch fit or is that DMF?
Ta
Re: Hdi90 clutch upgrade
Posted: Mon May 01, 2017 11:24 pm
by PeterN
Yes the 110 hp clutch uses a DMF. Clutch life depends largely on how you drive it, my first 406 had done 246K on the originals, if it is actually slipping you can extend its life by many miles by not letting it slip - and improve its fuel consumption. :wink:
Posted: Tue May 02, 2017 9:02 pm
by piglet
So no upgrade available without going to a 'performance part' ?
Posted: Tue May 02, 2017 9:11 pm
by GingerMagic
Some people fit a 90 solid flywheel in a 110 as an upgrade - so think of it as already having a performance flywheel...... 8)
A standard clutch will easily cope with up to 150bhp, with the solid flywheel so no need to upgrade.
Posted: Wed May 03, 2017 10:08 pm
by piglet
Standard it is then.
Any brands to avoid? I wouldn't fit a really cheap one anyway, rather just do it once.
Posted: Wed May 03, 2017 10:19 pm
by GingerMagic
LUK - cheap enough using some weekend discount code from CP4L or similar...
Type in the code - ' forum40 ' at GSF - to get one for £83 delivered :cheesy:
Posted: Thu May 04, 2017 11:44 am
by piglet
LUK, Valeo, Borg&Becks all OK?
Any other bits to change while it's out?
Posted: Fri May 05, 2017 6:05 pm
by dirtydirtydiesel
Luk is the o.e clutch
That's what I fitted & what came out,
also what John (jasper5) would recommend.
If doing the job yourself, some gearbox oil 2 liters for a drain & refill, both driveshaft seals, thrust release bearing
& the shaft thing that the clutch release bearing slides on.
The last item is folly to neglect, just ask our own highlander :roll:
As if or when it fails the whole job has to be repeated just to change a metal tube that cost less than a tenner :?
Posted: Fri May 05, 2017 6:30 pm
by GingerMagic
Don't forget the crank seal.....
It's only changeable when the flywheel is off, so may as well do it.. :cheesy:
Posted: Fri May 05, 2017 8:22 pm
by dirtydirtydiesel
:arrowu: Oh yeah Kelv I forgot why you sold your Monaco blue one :supafrisk: :arrowu:
Posted: Fri May 05, 2017 8:45 pm
by GingerMagic
It was my donor car - I only got rid of it 2 days ago.....
I don't need a donor 406 anymore when we no longer have a 406 - only a Picasso and a T4 :?
Posted: Fri May 05, 2017 9:42 pm
by dirtydirtydiesel
GingerMagic wrote:It was my donor car - I only got rid of it 2 days ago.....
Forgive me Kelv,
I thought the Monaco blue executive became your donor when you replaced it due to clutch slippage,
due to oil contamination :?
Didn't you replace it with the China blue glx and robbed all the best bits off the executive.
Posted: Fri May 05, 2017 11:30 pm
by GingerMagic
Yes I did, and it stayed on my drive for another 6 months after I sold the GLX.... :oops:
