Hi I was hoping someone could help me find the torque spec for the 406 Coupe 1998 d8 v6
I'm going to be servicing it; need to know the torque requirements of the:
Oil Sump nut
Brake caliper bolts
Brake slider bolts
Wheel nuts
Spark plugs
Rocker cover gasket bolts
And any others you guys recommend
Much appreciated guys...
regards!
Torque specifications D8 406 Coupe V6 3.0
Re: Torque specifications D8 406 Coupe V6 3.0
If you Google it there is a very useful site that pops up with all the torque settings that you need
2006 BMW e61 535d m-sport
run's for cover
dirtydirtydiesel wrote:If you Google it there is a very useful site that pops up with all the torque settings that you need
Had no luck finding it for the exact model when I googled it, that's why I'm here unfortunately... anyone out there with access to service box or a Haynes manual for the V6? ES9J4?
Ps you missd an 'e' in your signatur
Regards,
hooolagon wrote:dirtydirtydiesel wrote:If you Google it there is a very useful site that pops up with all the torque settings that you need
Regards,
I have been working car's & bikes for the last 35 years
Brake calipers mounting bolts, F off tight,
Slider bolts pretty tight,
Plugs, hand tight / screw in with wrench until it just bottoms then a quater of a turn, just to compress the sealing washer / 12lbf
Sump bolt, new coper sealing washer, again tighten up until bottoms & a quater of a turn / 18 lbf
Rocker cover bolts, I believe are 6mm into a alloy head so no more than 8 lbf, but have a look over on the coupe club forum
There is a how to on resealing Rocker covers
Hope this is of some help DDD.
Last edited by dirtydirtydiesel on Tue Jul 11, 2017 11:43 pm, edited 1 time in total.
run's for cover
Haha alright I'll improvise as I'm doing it! Cheers
Leicestershire in your signature is missing an e
Thanks,
Thanks,
hooolagon wrote:Haha alright I'll improvise as I'm doing it! Cheers
Thanks,
Missing an e, fixed
Probably had one too many 25-30 years ago
run's for cover
Come to think of it your offer to help people in Leicestershire, (however you spell it), could be seen as discriminatory to people in neighbouring counties.
