Oil is going down a bit, nothing on the undertray and the engine looks reasonably clean except for oil pooling around the injectors.
But not enough to account for the loss, so is she starting to burn oil at 120K? Hope not.
Anyway a new rocker cover gasket wouldn't hurt, are they all the same for the 2.0 Hdi?
Is there anything else to check?
Thanks in advance.
Losing oil, rocker cover?
Re: Losing oil, rocker cover?
Answering my own thread.
Changing rocker cover seal/gasket harder than it looked.
Top timing belt cover has to come off and the complicated bracket holding the injector harness has to be loosened.
Plus the new seal fell out everytime I turned it over, stuck it in with grease.
See if that dries it up.
Thank you for listening!
You're welcome
(sorry
What do you mean here? The seal comes out when you start the engine?piglet wrote:Plus the new seal fell out everytime I turned it over
Current "fleet":
2003 406 Estate 2.0HDi 110 - 7 seater - just hit 710.000 kms
2001 Citroen Saxo 1.6i 8v 100
Previously owned:
2000 406 Sedan 2.0 HDi 90
Previously owned:
I read that as when he turned the cam cover over but I see what you mean
Just needs a few dabs of, well, anything really.
I like the way you all say nothing and let me struggle through the job.
It fell out every time I turned the cam cover over and got it into position, It was late and my back was aching by then.
