question for james our master mechanic???
trem1
Post by trem1 »
i had a little problem with my drivers window today, it wouldnt close it would go so far up then appear to hit an invisible object and return back down, well i kept trying until it would'nt work at all :cry: well i figured it must have some kind of thermal cut-out so i left it alone for ages and ages(about3 mins really) and it still wouldnt close :evil: so of to the stealers i went, to keep the story short the mechanic came out pressed the button and guess what :?: yep it worked fine :evil: anyway he said it was a dry rubber *oo-er-missus* and sprayed the rubber with something out of a small areosol can with a peugeot lion on it.
the big question is WHAT was in the can james any ideas cos its left a greasy residue on my window but i dunno what it could be, surely not some sort of grease, what do you think :?: :?:
Benner
Post by Benner »
Yeah I've had exactly the same thing ever since I owned my 406. I've just learnt to live with it and found that if you turn off the engine but still leave the electrics on it will close fine.
But why does it do it James? Is it due to an increased resistance hense the stuff sprayed on trem1's window?
wes1001
Location: Sticky out bit, right on the tip of Kent, practically in the channel !!
Post by wes1001 »
If the battery has been disconnected for any period of time then the cars brain has to re-learn where the pinch point is on the window. Keep pressing the up button and the window will go up in measured increments. Once it reaches the top , hold the button for 10 secs then lower all the way down. Repeat this process a few times and eventually when you hard press the button ( i.e. up in one press ), it will close all the way. Any silicone based spray that contains teflon or molybdeum should work on the rubbers.
jameslxdt
Post by jameslxdt »
the auto up function on the window needs to be reprogrammed and will keep giving you these symptoms, as wes1001 said, the stuff he would have sprayed would be wurth silicone spray, its expensive stuff but does the job
though thinking about it trem, it could be a sign of the dreaded BSi failure :shock:
there maybe some software to cure this though, ill ask my dad if i remember
Benner
Post by Benner »
This bsi thing comes up quite often. What exactly is it? And i'm guessing its expensive?
jameslxdt
Post by jameslxdt »
the BSi is a Built in Systems Interface, its basically one computer which controls all the electronics within the car, ranging from the electric mirrors to the engine immobiliser, if its electric the BSi controls it
I am glad D8s don't have these BSI thingies :P
jameslxdt
Post by jameslxdt »
the very late D8.5 did though
Benner
Post by Benner »
See there is a good reason why we bought older cars Captain Jack. :cheesy:
This tells you a bit about the BSi too
Tremmy, I reckon the window rubber was just a bit tight and the window thought you had got your head stuck in there and backed off. Hopefully it will be ok.
wes1001
Post by wes1001 »
Damn that BSI sounds like one expensive tempremental bit of kit
sometimes i come on here just to laugh at weltons new sig :cheesy:
