Hi folks!
Only one part is missing from my complete timing tool kit for EW12J4: part number is 0189C. This is for flywheel lock.
I would like to ask for dimensions of this part if anyone has that.
I was considering to buy it from store - but the full kit is €200+, and if I need only this one still €50 - so none of them are feasible.
Thank you for any help!
Timing tool for ew12j4 (2.2i)
Re: Timing tool for ew12j4 (2.2i)
Can't help with the dimensions but a complete kit including this part is available on ebay for £29.99
2006 BMW e61 535d m-sport
run's for cover
'wrong end' of an 8mm (I think) drill works fine....
Unfortunately kits around this does not include this 0189C part nr. tool.dirtydirtydiesel wrote: ↑Sun Mar 31, 2019 10:25 pm Can't help with the dimensions but a complete kit including this part is available on ebay for £29.99![]()
On the other I need only the dimensions & 20 min and it's going to be done with turning.
Doggy: yes, the other side of the crankshaft is 8 mm - Haynes manual mentioned that. Thanks!
Correct me if I'm wrong
Your after the part in your attached picture no.
If so have a look at this item no 254057392960.
run's for cover
Last time I did mine, I found there was a small gap between the lower bellhousing cover plate and the block casting, through which you could see a section of the flywheel as you turned the engine. (Car on ramps, lying under the sump, turning crank pulley bolt with a ratchet).
I could see the timing hole passing this opening a few degrees before it aligned the timing hole in the block, apply gentle pressure to your locking pin while slowly rotating the engine and it slips into place.
