disconnecting that naughty EGR
Posted: Fri Jul 26, 2019 7:05 am
by bigknickers
Hello gang, I'd like to disconnect the EGR on my 52 plate 110 hdi, I understand I only have to pull off a vacuum pipe from a solenoid........YIPPEE........however, I'm an absolute *wat with car mechanicals...................can anyone spoon feed me?
On a seperate note, I understand the MOT test got harder in May 2018.....does that affect us sensible people driving the greatest car on the planet?
Re: disconnecting that naughty EGR
Posted: Fri Jul 26, 2019 7:18 am
by GingerMagic
Morning :cheesy:
Have a look on top of your engine, towards the back, and you will see a round metal thing tucked away - find the little black pipe that goes into this and pull it off - bung a screw in the end of the pipe 8)
If you don't bung this pipe then you'll lose vacuum which will affect the turbo...
This will only have positive results come MOT time as your emissions should be lower ( if you've driven it with enthusiasm )- any scaremongering about diesels doesn't include the 406 as it's pre-Euro5 legislation.
Posted: Fri Jul 26, 2019 8:21 am
by bigknickers
Good man Ging..................gonna have a look in a sec!
So, it seems, if a person wants a diesel car..................they should only have an old one!! being a car snob is a very costly exercise
Posted: Fri Jul 26, 2019 10:34 am
by bigknickers
Ging...................I'm scared! there's lots of round bits!!!!.....do you mean the black round bit that's very close to the r/h injector which seems to connect to a big ol pipe that comes from a small radiator thing (intercooler??) at the front. If this is the round thing you mention, it appears to have a tiny black plastic pipe that goes to a solenoid? on the firewall bulkhead (there are three solenoids together n this one is the r/h one)
Posted: Fri Jul 26, 2019 11:09 am
by GingerMagic
I think so...
The EGR is a big solid metal lump like a UFO, and is directly above the turbo at the back, should only be a thin black pipe at the bottom of it, but yes, the black pipe leads to the middle solenoid...
It looks like this...
https://rover.ebay.com/rover/0/0/0?mpre ... 3303396806
Posted: Fri Jul 26, 2019 12:06 pm
by bigknickers
Pheeeewey............that wasn't what I was looking at! (told you I was a *wat), right, got the sucker, so cut the pipe n bung a screw up the end that leads back to that solenoid?
Posted: Fri Jul 26, 2019 1:06 pm
by GingerMagic
Yes, but don't cut the pipe - just pull it off...
An EGR blank is best for the long term, but just bunging the pipe is a good way to disable it short term ( 5 years on my wife's Picasso..)
Posted: Fri Aug 02, 2019 2:51 pm
by bigknickers
Many thanks Ging.....................pipe bunged!.............let's face it, if it lasts for 5 years, that'll be longer than the supply of parts (especially comm 2000units), they must be the most replaced part (apart from the tyres)
