Greetings Pug lovers. My D9 has just passed its MOT with very minor advisories BUT has developed a clunk clunk clunk noise from the front drivers side wheel. Only happens when I turn the steering wheel. Not noticed any abnormal handling or vibration so am thinking maybe it's a cv joint gawn orft.
Haven't lifted the wheel to check for play yet, plus it's November and not really the sort of weather for worling on cars outside, so, im the meanwhile, just thought it might be worth asking youse guys what you think?
Thanks in advance all.
Rob
Clunk clunk clunk when turning... New drive shaft time?
406 Exec 2.0 HDi 110
Re: Clunk clunk clunk when turning... New drive shaft time?
It is a very good guess. It could however also be top mount bearing. If the cv joint gaiter is’nt torn it is most likely the the top mount bearing. You need to remove the shock in order to check. It is often an overseen problem simple because it is very timconsuming to do the repair.pugnut wrote:Greetings Pug lovers. My D9 has just passed its MOT with very minor advisories BUT has developed a clunk clunk clunk noise from the front drivers side wheel. Only happens when I turn the steering wheel. Not noticed any abnormal handling or vibration so am thinking maybe it's a cv joint gawn orft.
Rob
If you jack up both front wheels and work the steering while listening to it, you'll soon know if it's the strut top bearings.
If your strut top bearings are gone & your on original springs
BEWARE
They snap for fun
They are a crap design, my car when purchased had two replacement one's
That was 70 k ago & 65 k at the time, I've replaced both of them once & yes greased them liberaly
Now they need replacement again now on 132k.
As I said, crap design.
BEWARE
They snap for fun
2002 110 HDi estate, Rapier in monaco blue! ( found quite a bit more power ) SOLD I've sorted the airbag light
2006 206 1.4 16v sport in Aegean blue ( wife's shopping trolley )
2006 BMW e61 535d m-sport run's for cover
It's an epidemic, most modern's have a problem with broken springs, if you look on most car forums you'll find them. They always used to last forever (just gradually self-lowering) but I think it's the use of different materials and maybe they're smaller to be lighter. However, PSA don't do themselves any favours because, while a lot of manufacturers design the seats to catch broken springs, PSA don't and they can end up taking out ABS sensors, drive shaft boots and tyres. Saying that though, all of the 406 broken springs on here seem to happen when the car's either parked or being driven slowly.
Did you check the wheel bolts?
