Engine doesn't start after revving for red line. 7000rpm
dexter895
1.6 8v
Post by dexter895 »
My 406 is 1999 1.8 manual version. Yesterday morning i tried to start the car didn't start (didn't even cranked) But after few hours i tries again and it started up. Then I reved to red line while in neutral. After hitting redline engine stopped. Now it's only cranking and doesn't start up.
I'm afraid i valve bounced. Is there anything i can try?
PeterN
Re: Engine doesn't start after revving for red line. 7000rpm
Post by PeterN »
Does the engine turn over faster than normal when you try to start it? If so the cambelt has probably broken. Assuming yours uses a cam belt, I only know about diesels.
dexter895
1.6 8v
Post by dexter895 »
PeterN wrote: Sat Sep 26, 2020 9:27 am Does the engine turn over faster than normal when you try to start it? If so the cambelt has probably broken. Assuming yours uses a cam belt, I only know about diesels.
I doesn't seems so. But i checked the spark plugs, they don't get power.
I wonder if there is damage to the crank sensor?
CHRISHDI110
Post by CHRISHDI110 »
i wonder if the rev limiter kicked in and is "stuck" on so has stopped the spark? im not familiar with more "modern" cars so not sure where or what the limiter is.
1986 Lotus Excel SE
2002 406 hdi 110
406, better late than never.
It's set in the ecu. I dunno, belt jumped a tooth, dropped a valve, endless possibilities.
CHRISHDI110
thought it might be summert to do with ecu (promise)! loss of spark is going to keep me thinking.
1986 Lotus Excel SE
2002 406 hdi 110
