Slave Cylinder pipework
Posted: Mon Nov 29, 2021 2:57 pm
A couple of days ago my clutch pedal went straight to the floor. Upon investigation, the rubber section of pipe near the slave cylinder has been chaffing (over quite some time I suspect) and eventually worn through.
Is this a relatively easy run of pipe to remove? I can possibly get it repaired if it is.
Are replacements available?
As per my sig, the car is a 2003 2.2 HDi
