Page 1 of 2
Posted: Thu May 03, 2007 10:12 pm
by wafeeq
hi
under the cover lies the coils, there are three 8 mm bolts holding them, under them lives the spark plugs
there are only 2 types recommended by peugeot
EYQUEM: RFN52 HZ
Bocsh: FR 8 ME
other manufacturers like Beru, Denso have equivellant numbers.
But I believe you should stick to bosch
Posted: Thu May 03, 2007 11:53 pm
by Benner
wafeeq wrote:hi
EYQUEM: RFN52 HZ
Bocsh: FR 8 ME
I have had problems with Bosch's in the past so have been put off to be honest. I have always liked Denso's.
Posted: Fri May 04, 2007 10:45 am
by wes1001
Second the Denso's - i run iridiums in my turbo and the pick up seems a little sharper - could all be in my mind tho'
Posted: Fri May 04, 2007 7:32 pm
by jameslxdt
denso are too expensive and are best left on jap crap
ngk's are the best for pugs, if you went to pug for plugs you would either get eyquem if your really unlucky, bosch if your lucky, or proper ngk's if the parts man likes you
Posted: Fri May 04, 2007 7:37 pm
by DaiRees
The
only plugs I could get for the HPi were dealer supplied Bosch ones at £47 a set
You told me that James!
Posted: Fri May 04, 2007 7:42 pm
by jameslxdt
i know, but we aint talking about the [s]crappy[/s] HPi now are we?
Posted: Fri May 04, 2007 8:46 pm
by DaiRees
Cheek!
Actually maybe you can help me here, cold engine, accelerating from low revs with a light throttle I feel a bit of hesitation, dunno if it's a misfire or something else. Doesn't do it when the engine's warm, doesn't do it when you give it full throttle. Any ideas?
Posted: Fri May 04, 2007 8:55 pm
by jameslxdt
sticky cam follower or duff injector
when was the last time it had an oil change?
Posted: Fri May 04, 2007 8:58 pm
by DaiRees
COUGH18months
COUGH
Posted: Fri May 04, 2007 9:01 pm
by jameslxdt
are you one or two year servicing intervals?
Posted: Fri May 04, 2007 9:03 pm
by DaiRees
2 years or 20000 miles, and in my defense she's prolly only done about 12000 since the last one, but I am aware that it's good practice to do "in-between" servicing.
Posted: Fri May 04, 2007 9:05 pm
by DaiRees
Posted: Fri May 04, 2007 9:08 pm
by jameslxdt
yeah, i think an oil change is called for, take it for a 30 min motorway blast to get the old oil red hot then drain it, and use castrol edge 0w40
or mobil one 5w40
Posted: Fri May 04, 2007 9:15 pm
by DaiRees
Will do boss, I'll report back when it's done.
Cheers Matey
Posted: Fri May 04, 2007 9:17 pm
by jameslxdt
no problem
is the problem anything like what happend before with the egr?
