starting problem
puglover
starting problem
Post by puglover »
hi all, i have an annoying starting problem with my pug
when the weather is warm i put my key in enter the code turn the key and it starts and won't idle or rev properly.
i have to turn engine off turn ig. off and remove key wait for imobilizer to to kick in then start the car again.
i could do this process about 3 times before it will run properly
has anyone got any ideas???
would be welcomed
btw cold starting not a problem...
jameslxdt
Post by jameslxdt »
thats not an immobiliser problem, if it was it would out right refuse to start, it could be a sticky cam follower, duff injector or coolant sensor
puglover
Post by puglover »
thanks for the reply james i didnt think it was an imobilizer prob i was thinking somwhere down the line of an auto choke or equivalent but will investigate them when i got time
thanks very much for your help
Malachy
2.2 16v
Post by Malachy »
what engine is it? could be a sticky fuel cut off solenoid on a TD or a sticky ICV that corrects on second restart
1996 306cab with a few mods
1997 Mercedes C230 Kompressor sport
puglover
Post by puglover »
hi mala yeah my engine is a 1.8 16v on an R plate
