tickover only ?
daddykins2
tickover only ?
Post by daddykins2 »
how come now i have paid to get myhdi pump nreconditioned, and my ecu rebuilt, my 406 only ticks over nothing else ?
the truth is out there
jameslxdt
Post by jameslxdt »
are you sure the accelerator cable is connected to the throttle pedal sensor?
daddykins2
yes checked all the obvious.. scanner says p0220. it lists 6 of the same fault but different numbers.. and six of another fault, but different numbers
jameslxdt
Post by jameslxdt »
is the throttle pedal sensor plugged in?
if it is then you need a new sensor most likely
very common on the HDi 110
daddykins2
does anyone have any ideas how much they are.. also. there is a devise broken,on the large hose that connects the intercooler to the engine a small pipe connects to it as well
jameslxdt
Post by jameslxdt »
i think they about £50
have you got a pic of the thing you are on about?
daddykins2
no sorry.. to complicated for me,, it is on the righthand radiator side as you stand in front of the car,, it`s a 110 td and if you plug the pipe the tickover drops down to normal
jameslxdt
Post by jameslxdt »
what other fault codes have you got?
was there one for egr or boost pressure control solenoid?
daddykins2
yes 12 of them p0220.p0220.p0220.p0120.p0120.p0120.p0235.p0235.p0200.p0200p0190.p0190.
now that will confuse anyone... i hav`nt made a mistake.that is what the trouble codes say
