remaps
Most 'modern-ish' TD's can be mapped if they have electronic control of the fuelling/turbo.
The 2.1 td can be remapped.
My missus old 318tds can be remapped.
I don't think you can remap an old 1.9td in the 405's.
Common rail is just an advanced high pressure system for more efficient use of the Diesel fuel really. Most pre-common rail Diesels have electronic control and can be remapped.
- jameslxdt
only diesel engines that have distributor pumps with full electronic control, i.e. total fuel quantity etc.
i.e. PSA 2.1 td 110, VAG 1.9 tdi 110 or 90, BMW 2.5 tds or 1.9 tds
any common rail can be remapped with the exception of a few, such as the PSA HDi's with siemens fuel system
- jameslxdt
its a very secure system thats designed only to run as it is, and doesnt run with any remap
- jameslxdt
yes, as i said above, the units such as the PSA 2.1 TD and the early VAG 1.9 TDi and 2.5 TDi engines
