Starting (or non starting) problem 1.9TD
Posted: Sat Jun 02, 2007 8:31 pm
by Jay_Jones
[align=center]Hi everyone, new to the 406 only had it a week and now i have a problem
, when i got the car it was great after changing the battery, then on tuesday it didnt start. so went out and got glow plugs and a fuel filter..... after fitting them turned the key and still not starting.... diesel is getting to the injector pump but not coming out of it 2 the injectors..... does anyone have any idea whats going on?? P.S. Its a 1997 R reg 406 1.9TD Estate
Thanks in advance
Jay
Posted: Sat Jun 02, 2007 8:55 pm
by robbie123
Your typing the code in the keypad ok right?
It should have a red light and then when you type the code in, it should turn green. It does sound like an immobiliser problem. I had a mechnanic take a look at my car while I was at uni. He phoned me saying it wouldn't start and fuel wasn't getting to teh injectors. Turns out he didn't know about the code so wasn't typing it in!!!!!!!!!!
by jameslxdt
yeah, sounds like either an immobiliser problem or a seized shut stop solenoid
Posted: Sat Jun 02, 2007 9:02 pm
by Jay_Jones
Hi thanks for getting back to me, The 406 doesn't have a keypad is there a way of testing the solenoid or deactivating the immobiliser? the remote plip is broken so just use it as a key as i am not going to pay Peugeot £185 for a replacement plip...
Posted: Sat Jun 02, 2007 9:04 pm
by jameslxdt
unfortunatley there's no way to test the solenoid on a 406 as they put a very thick strong shield in the way of it and you have to remove the pump and drill out the shear bolts holding this shield on to change it
Posted: Sat Jun 02, 2007 9:24 pm
by Jay_Jones
Oh Bugger! well is there a way of removing or bypassing the immobiliser system? i have a feeling its something to do with the immobiliser.
Posted: Sat Jun 02, 2007 9:27 pm
by jameslxdt
only by doing what i said above, get a new stop solenoid and cut out the coded module wired to the solenoid and run a wire with an igntion feed to the solenoid
Posted: Sun Jun 03, 2007 10:11 am
by Jay_Jones
ok will have a go at that today and let you know how i get on, thanks for the advice
Jay
Posted: Sun Jun 03, 2007 10:20 pm
by Jay_Jones
managed to get it running after 6 hours of cutting and drilling, managed to do it with the pump still fitted as the bolts came loose with the vibration from grinder.... it was the immobiliser module next to the solenoid, as the solenoid is working fine.... thanks for all the help guys.
Regards
Jay
Posted: Fri Jun 29, 2007 7:14 pm
by eryk
O yeah! Sounds delicious
Mate, can you tell me exactly in steps what you've done with car. I Feel i have same problem with my 406.
Regards
Eric
Posted: Wed Jul 04, 2007 9:11 am
by eryk
Jay, i've lost PM from You. Can you send me that again or mailme eryk -at- hot -dot- pl
Regards,
