Radiator swap
candidate
Radiator swap
Post by candidate »
Probably going to be doing a radiator swap on my D8 1.9 dt (no aircon) at the weekend, any tips that Haynes doesn't cover before i start?
Cheers in advance.... :?
Make sure you've got some zip ties and a cordless drill to hand! You may need them to re-attach the undertray as the bolts are susceptible to rusting...
jameslxdt
Post by jameslxdt »
no need to take the undertray off, the rad come out the top, but the intercooler hoses can get right in the way
Surely you'd have to drain it first? From yesterday's experience I can safely say that draining it with the undertray in situ results in coolant everywhere even if you try to tilt it towards a bucket...
jameslxdt
Post by jameslxdt »
i dont usually bother to drain it, as so much coolant gets stuck in the system anyway
candidate
Post by candidate »
Cheers guys,
Not too worried about the undertray, that disappeared on the M18 years ago when i hit a block of wood!! :shock:
