Silicon on a radiator?
Posted: Wed Jun 13, 2007 9:11 pm
by philg
I was fitting a upper mount to a 306 so jacked the engine upwards. In doing so the feed pipe to the power steering pump pushed against a radiator pipe. This radiator pipe broke off the radiator. The plastic broke in 2. And all the coolant poured out.
If i were to silicon the plastic part back on, and give it plenty of time to dry, would it hold?
The car is for sale and i dont want to have to fit another radiator. I just want rid of the car now!
Posted: Wed Jun 13, 2007 9:50 pm
I can't see Silicone holding chap.
'Araldite' might do temporarily.
Posted: Wed Jun 13, 2007 10:43 pm
by TooT
'No Nails' ????
Posted: Thu Jun 14, 2007 5:36 pm
by Molly's Dad
Try Evo-stik Hard Plastic adhesive. I've used it many times with good results (and a few times which didn't!) It comes in a small super-glue sized tube, but you only need a few drops. Says it works with PVC, ABS and acrylic.
Posted: Thu Jun 14, 2007 10:43 pm
by philg
I used 'U-pol PlastX' plastic glue/weld type stuff. It seems to be ultra strong, i'm banging some rad-weld type stuff into the radiator as well just incase i didnt get a perfect seal.
The Upol stuff is supposed to be used on bodywork, so i may even use it on my bumper!
